Model 5080
1" axles
4 two-piece pinion gear differential four-speed
2 pages 182.88KB
4-speeds have the brake drum mounted on the cluster gear shaft. Use Section IV of the service manual.
5080 transmission used in
1971 WorkHorse 800 model 1-0100
1974 B-80 4-speed model 1-0140 as listed in transmission service manual #492-4004 (May be 5084 as listed @ Toro)
5080 shown in the 1967 1057 and 1257 ipl with bevel pinion gears which is wrong. Suspect it is a typo and should be model 5058.
5080 uses 2 bevel pinions and 5058 uses 4 spur gears.
