Transmission Gear Uni-drive 3-speed 1.000in axle 4-pinion 5048 1965 IPL.pdf
2 Screenshots
Model 5048
1" axles with gear item #20 in illustration part #5577 (Axle part number 3904 is 10-5/8" long)
4 two-piece pinion differential three-speed
1 page 296.39KB
3-speeds have the brake drum mounted on the 11/44 (mushroom) gear. Use Section II of the service manual.
New shift rails in 1965
Model 5048 could be upgraded to a model 5053 with kit # 7168
5048 transmission used in
1965 model L-105 Lawn Ranger
1965 model L-155 Lawn Ranger
