Transmission Gear Uni-drive 3-speed 1.000in axle 4-pinion 5025 1962-1964 IPL.pdf
Model 5025
1" axles 2 of 3904 10-5/8" long
4 two-piece pinion differential three-speed
1 page 148.88KB
3-speeds have the brake drum mounted on the 11/44 (mushroom) gear. Use Section II of the service manual.
This parts list shows the 933168 roll pin for the shifter donut 5/32" x 13/16"
Replaced by 32121-114 spirol pin
3514 collar commonly called a donut
1239 dog-point set screw 1/4-20 x 3/4"
5278 straight shifter without collar or donut
Models 5025 & 5046 same except for shift lever bent to clear hydraulic pump
Model 5025 replaced 5007
Model 5025 replaced by 5046 for 1964, 5049 for 1965 and 5053 for 1966-1969
Model 5025 transmission used in
1962 model 32E
1962 model 32R
1962 model 502
1962 model 552
1962 model 702
1963 model 33E
1963 model 33R
1963 model 603
1963 model 633
1963 model 653
1963 model 753
1964 model 754
1964 model 854
1964 model 1045
