Engine Kohler K241 10hp Spec 4600-46858 IPL #TP-404-C.pdf
tunahead72
Illustrated parts lists
68 pages 2.34MB
Issued 3/82 Revised 7/93
The following engines have the spark advance camshaft
K241, Suffix prior to “D”
K241 (10hp or 7.5KW)
1963 model 953 - Uses K241S-46135A
1964 model 1045 - Uses K241AS-46219A
1964 model 1054 - Uses K241S-46215A
1965 model 1054A - Uses ? K241S-47176 - Looks wrong and K301-47176 is a 12hp service engine
1965 model 1055 - Uses K241AS-46219A
1965 model 1075 - Uses K241AS-46219A
1966 model 1046 - Uses K241S-46219A
1966 model 1056 - Uses K241AS-46333D - Should be K241S?
1966 model 1076 - Uses K241AS-46333D - Should be K241S?
1967 model 1057 - Uses K241S-46333D
1967 model 1067 - Uses K241S-46333D
1967 model 1077 - Uses K241S-46333D
1972 Charger 10 model 1-0410 - Uses K241S-46636D
1972 Raider 10 model 1-0301 - Uses K241S-46636D
1973 10hp 8-Speed model 1-0360 - Uses K241S-46636D
1973 10hp 8-Speed model 1-0365 - Uses K241S-46636D
1973 10hp Automatic model 1-0470 - Uses K241S-46636D
1973 10hp Automatic model 1-0475 - Uses K241S-46636D
1973 Raider 10 8-Speed model 1-0360 - Uses K241S-46636D - Made in Belgium
1974 B-100 Automatic model 1-0510 - Uses K241S-46636D
1974 C-100 8-Speed model 1-0390 - Uses K241S-46636D
1974 Raider 10 4-Speed model 1-0393 - Uses K241S-46636D - Made in Belgium
1974 Raider 10 8-Speed model 1-0390 - Uses K241S-46636D - Made in Belgium
1975 B-100 Automatic model 1-0511 - Uses K241S-46636D
1975 C-100 4-Speed model 1-0394 Uses ?
1975 C-100 8-Speed model 1-0391 - Uses K241S-46636D
1975 Raider 10 4-Speed model 1-0394 - Uses K241S-46636D - Made in Belgium
1976 B-100 8-Speed model 61-10K801 - Uses K241S-46636D
1976 B-100 8-Speed model 61-10K802 - Uses K241S-46636D
1976 B-100 8-Speed model 61-10K803 - Uses K241S-46636D
1976 B-100 8-Speed model 61-10K804 - Uses K241S-46636D
1977 B-100 8-Speed model 71-10K801 - Uses K241S-46756D
1977 C-100 8-Speed model 71-10K8 - Uses ? - Made in Belgium
1978 C-101 8-Speed model 81-10K801 - Uses K241AS-46766D
1979 C-101 8-Speed model 91-10K801 - Uses K241AS-46766D
1979 C-101 8-Speed model 91-10K802 - Uses K241AS-46766D
1979 C-101 8-Speed model 91-10K892 - Uses ? - Made in Belgium
1980 C-105 8-Speed model 01-10K801 - Uses K241AS-46805D
1981 C-105 8-Speed model 01-10K802 - Uses K241AS-46812D
1982 C-105 8-Speed model 01-10K803 - Uses K241AS-46812D
1983 C-105 8-Speed model 11-10K801 - Uses K241AS-46812
1984 C-105 8-Speed model 11-10K802 - Uses K241AS-46812
1985 310-8 model 21-10K801 - Uses K241S-46849 according to Toro
1986 310-8 model 21-10K802 - Uses K241-46863 - First with low oil switch
The following were supplied to Wheel Horse according to Kohler records
K241-46135 - 1963
K241-46215 - 1964
K241-46219 - 1964, 1965, 1966
K241-46323 - ?
K241-46333 - 1966, 1967
K241-46416 - ?
K241-46552 - ?
K241-46586 - ?
K241-46636 - 1972, 1973, 1974, 1975, 1976
K241-46643 - ?
K241-46756 - 1977
K241-46766 - 1978, 1979
K241-46805 - 1980
K241-46812 - 1981, 1982, 1983, 1984
K241-46849 - 1985 - Not in this ipl and may be a mistake at Toro but listed in PSB #301g
K241-46863 - 1986 - First with low-oil switch
