WH61-90 #134 Ignition switches 1972 models.pdf
2 Screenshots
3 pages 105.59KB
5 pages 287.90KB
Dated February 1972
Ignition switch terminal locations
Only 2 switches identified
This is only a guess
Switch ignition Battery
{Illustration 1 is 101917} Replaced by 92-6785 and still available June 10, 2014 (5-terminal 4-position Battery ignition Electric start or Magneto ignition with a kill relay)
101917 switch used on
1972 Bronco 14 model 1-0422
1972 Bronco 14 model 1-0423
1972 Charger 10 model 1-0410
1972 Charger 12 model 1-0401
1972 Commando 800 4-Speed model 1-0110
1972 Raider 8 model 1-0330
1972 Raider 10 model 1-0301
1972 Raider 12 model 1-0311 (This model also made in Belgium)
1972 Raider 14 model 1-0320
1973 8hp 4-Speed model 1-0120 - Horizontal shaft (Also made in Belgium as Commando 800)
1973 8hp 4-Speed model 1-0130 - Horizontal shaft - Commando 800?
1973 8hp 8-Speed model 1-0370 - Horizontal shaft
1973 10hp 8-Speed model 1-0360 ??????????????
1973 10hp 8-Speed model 1-0365
1973 12hp 8-Speed model 1-0350 ??????????
1973 12hp 8-Speed model 1-0353 - Listed in PSB #301E for 1973-74. Suspect 1973 is wrong ?????????
1973 12hp 8-Speed model 1-0354 - Listed in PSB #301E for 1973-74. Suspect 1973 is wrong ?????????
1973 12hp 8-Speed model 1-0355 - One made in Belgium and located in Wales
1973 14hp 8-Speed model 1-0340
1973 18hp Automatic model 1-0600
1973 18hp Automatic model 1-0601
1973 18hp Automatic model 1-0610
1973 18hp Automatic model 1-0620
1973 Raider 10 8-Speed model 1-0360 - Made in Belgium
1973 Raider 12 8-Speed model 1-0350 - Made in Belgium
1974 Raider 10 4-Speed model 1-0393 ????????????????? - May not be correct
Switch 92-6785 used on
72042, 264-6 Yard Tractor, 1994 (SN 4900001-4999999)
72043, 264-H Yard Tractor, 1994 (SN 4900001-4999999)
72062, 264-6 Yard Tractor, 1994 (SN 4900001-4999999)
72063, 264-H Yard Tractor, 1994 (SN 4900001-4999999)
72083, 266-H Yard Tractor, 1994 (SN 4900001-4999999)
72103, 268-H Yard Tractor, 1994 (SN 4900001-4999999)
72042, 264-6 Yard Tractor, 1995 (SN 5900001-5900796)
72042, 264-6 Yard Tractor, 1995 (SN 5900797-5999999)
72043, 264-H Yard Tractor, 1995 (SN 5900001-5901475)
72043, 264-H Yard Tractor, 1995 (SN 5901476-5999999)
72062, 264-6 Yard Tractor, 1995 (SN 5900001-5900227)
72062, 264-6 Yard Tractor, 1995 (SN 5900228-5999999)
72063, 264-H Yard Tractor, 1995 (SN 5900001-5900498)
72063, 264-H Yard Tractor, 1995 (SN 5900499-5999999)
72084, 266-H Yard Tractor, 1995 (SN 5900001-5999999)
72103, 268-H Yard Tractor, 1995 (SN 5900001-5900600)
72103, 268-H Yard Tractor, 1995 (SN 5900601-5999999)
Switch Ignition Magneto
{Illustration 2 is 8362} Still available June 10, 2014 (5-terminal 4-position Magneto ignition HD electric start without solenoid)
8362 switch used on
1969 Charger 10 model 1-7041
1969 Charger 12 model 1-7241
1969 Electro 12 model 1-7245
1969 Raider 10 model 1-6041
1970 Charger 12 model 1-7251
1970 Charger 12 model 1-7252
1970 Charger 12 model 1-7253
1970 Electro 12 model 1-7255
1970 Raider 10 model 1-6051
1970 Raider 12 model 1-6251
1970 Raider 12 model 1-6252
1970 Raider 12 model 1-6253
1971 Bronco 14 model 1-0420
1971 Bronco 14 model 1-0421
1971 Charger 12 model 1-0400 - Uses breakerless magneto ignition
1971 GT-14 model 1-0500
1971 GT-14 model 1-0501
1971 Raider 10 model 1-0300
1971 Raider 12 model 1-0310 - Uses breakerless magneto ignition
1972 Charger 12 model 1-0402 - Uses breakerless magneto ignition
{Illustration 3 is 101876} Discontinued June 10, 2014 - 1972-73 GT-14
Should be a suitable replacement ignition switch 92-6785
2 pages 91KB
101876 switch used on
1972 GT-14 model 1-0502
1972 GT-14 model 1-0503
1973 GT-14 Automatic model 1-0502-8 - Listed in attachment interchange Not listed at Toro
{Illustration 4 is 101482} Replaces 4987 and 7572 Still available June 10, 2014 (3-terminal 3-position Magneto ignition HD electric start without solenoid)
How I figured out the 1972 switches
[Switch 3656 used 1961-63 1965-66]
[Switch 6890 used 1967]
[Switch 4988 battery ignition w/starter-gen used 1964-67 superseded to 7263] [Switch 7263 battery ignition used 1967-68]
[Switch 102820 used 1970-71, 1973-74, 1976-77, 1979]
[Switch 101917 for battery ignition used 1970-73 superseded by 92-6785] [Switch 92-6785 used 1994-2007]
[Switch 8362 for mag ignition used 1969-72]
[Switch 7572 used 1968-70 superseded to 101482] [ 101482 switch magneto ignition w/starter-gen used 1971-75]
