Engine Kohler K 91 K161 K181 OM #ENS-593-F.pdf
tunahead72
Operating & Maintenance Instructions
Low resolution 16 pages 3.09MB
High resolution 16 pages 4.16MB
Dated 3/84
Revised 7/97
The following engines have the spark advance camshaft
K161, Suffix prior to “J”
K181, Suffix prior to “D”
K91 (4 HP)
1960 model 400 - Uses K91-31388a
1961 model 401 - Uses K91-41437a according to Toro. No other record found.
K161 (7 HP)
1961 model 701 - Uses K161S-28522e - Only model to use two starter/generator belts
1962 model 702 - Uses K161S-28626e
1963 model 753 - Uses K161S-28626e
1964 model 704 - Uses K161T-28937e
1964 model 754 - Uses K161S-28626e
1976 B-60 8-Speed model 61-07K801 - Uses K161T-281269j
1976 B-60 8-Speed model 61-07K802 - Uses K161T-281269j
1977 B-60 8-Speed model 71-07K801 - Uses K161T-281269j
K181 (8 HP)
1964 model 854 - Uses K181S-30108a
1965 model 855 - Uses K181S-30108a
1965 model 875 - Uses K181S-30108a
1966 model 856 - Uses K181S-30108d
1966 model 876 - Uses K181S-30108d
1967 model 857 - Uses K181S-30108d
1967 model 867 - Uses K181S-30108d
1967 model 877 - Uses K181S-30108d
1968 Commando 8 model 1-4831 - Uses K181S-30108d
1972 Commando 800 4-Speed model 1-0110 - Uses K181S-30461d
1972 Raider 8 model 1-0330 - Uses K181S-30461d
1973 8hp 4-Speed model 1-0120 - Uses K181S-30461d
1973 8hp 4-Speed model 1-0130 - Uses K181S-30461d
1973 8hp 8-Speed model 1-0370 - Uses K181S-30461d
1974 B-80 4-Speed model 1-0140 - Uses K181S-30461d
1974 B-80 4-Speed model 1-0145 - Uses K181S-30461d
1975 B-80 4-Speed model 1-0141 - Uses K181S-30629d
1976 B-80 8-Speed model 61-08K801 - Uses K181S-30629d - Incorrectly named a B-60 @ Toro
1976 B-80 8-Speed model 61-08K802 - Uses K181S-30629d - Incorrectly named a B-60 @ Toro
1976 B-80 8-Speed model 61-08K803 - Uses K181S-30629d
1976 B-80 8-Speed model 61-08K804 - Uses K181S-30629d - Incorrectly named a B-60 @ Toro
1977 B-80 8-Speed model 71-08K801 - Uses K181S-30629d
1978 C-81 8-Speed model 81-08K801 - Uses K181S-30700d
1979 C-81 8-Speed model 91-08K801 - Uses K181S-30700d
1979 C-81 8-Speed model 91-08K802 - Uses K181S-30700d
1980 C-85 8-Speed model 01-08K801 - Uses K181S-30743d - Incorrectly named a C-81 @ Toro
1980 C-85 8-Speed model 01-08K802 - Uses K181S-30743d - Incorrectly named a C-81 @ Toro
1981 C-85 8-Speed model 01-08K802 - Uses K181S-30743d - Incorrectly named a C-81 @ Toro
1982 C-85 8-Speed model 01-08K803 - Uses K181S-30743d
1983 C-85 8-Speed model 11-08K801 - Uses K181S-30803
