1956-1999 Chart belt
20 pages 1.77MB
Belt sizes on the last pages
Mistakes in mower belt chart
1967
RL-367 drive belt lists 1587 Correct belt is 1563
1968
5-1361 drive belt lists 8975 Correct belt is 1563
5-1362 drive belt lists 8975 Correct belt is 1563
5-2321 drive belt lists 8975 Correct belt is 1577 replaced by 7430
5-2322 drive belt lists 8975 Correct belt is 1577 replaced by 7430
5-2361 drive belt lists 1587 Correct belt is 1577 replaced by 7430
5-2362 drive belt lists 1587 Correct belt is 1577 replaced by 7430
1969
5-8321 drive belt 8975 (1/2" x 58") [1561 in the belt chart is wrong]
1970
5-8322 drive belt 8975 (1/2" x 58") [104865 in the belt chart is wrong]
1971
5-1000 drive belt 9782 (1/2" x 69") [9783 in the chart is wrong]
1978
85-42MR01 drive belt 108834 is correct as per PSB #272
1979
95-42MR01 drive belt 108834 is correct as per PSB #272
95-42MR02 drive belt 108834 is correct as per PSB #272
1980-1983
05-42MR01 drive belt 108834 is correct as per PSB #272
1983
The 2nd A5-42MS02 in the chart should be A5-48MS02
1984
Model 23-11BP03 tractor shows belt 108491 (1/2" x 67"). Believe it should be 108503 (1/2" x 65.25") for 05-32XS02 mower on the A-111 5-Speed
05-42MS02 should be 05-42MR02
1985
There is one model number missing for every style and size of deck listed. Do a search of the Files for a deck model number if it is not listed in the chart. The belts are listed there.
1991
Model C5-60SC02 not in the chart { (Drive belt 113072 (1/2" x 103") (Spindle belt 112449 (5/8" x 131.25") }
1993
8-32 Rear Engine Rider Recycler model 70042 - Mower drive and spindle belt 92-0875 (1/2" x 58" @ Gates) [Belt 47-1420 (1/2" x 65.56") in belt chart is wrong]
10-32 Rear Engine Rider Recycler model 70080 - Mower drive and spindle belt 92-0875 (1/2" x 58" @ Gates) [Belt 47-1420 (1/2" x 65.56") in belt chart is wrong]
12-32 Rear Engine Rider Recycler model 70120 - Mower drive and spindle belt 92-0875 (1/2" x 58" @ Gates) [Belt 47-1420 (1/2" x 65.56") in belt chart is wrong]
12-32 Rear Engine Rider model 70140 - Mower drive and spindle belt 92-0875 (1/2" x 58" @ Gates) [Belt 47-1420 (1/2" x 65.56") in belt chart is wrong]
1994
10-32e Rear Engine Rider Recycler model 70100 - Mower drive and spindle belt 92-0875 (1/2" x 58" @ Gates) [Belt 47-1420 (1/2" x 65.56") in belt chart is wrong]
12-32e Rear Engine Rider Recycler model 70141 - Mower drive and spindle belt 92-0875 (1/2" x 58" @ Gates) [Belt 47-1420 (1/2" x 65.56") in belt chart is wrong]
1996
78345 42`side discharge lists drive belt 108834 and spindle belt 106125 - Correct drive belt is 102742 and spindle belt 6738
78355 42`recycler lists drive belt 102742 and spindle belt 6738 - Correct drive belt is 108834 and spindle belt 106125
1997
1998
1999
1999 and 2000
79375 36" tiller for 5xi models
Front belt 98-8707 or 94-7877 (1/2" x 113.75" found with Google search)
Rear belt 98-8706 (1/2" x 92.66" found with Google search)
