  • Please Read
  • WANTED Outer Implement Drive Pulley #1608
    dmoore
    • Active
    WANTED....This is the outer pulley item #84 Wheel-Horse parts list. Item #1608
    User Feedback
    davidtmercer
    Posted
    Based on my quick research of this part.  I assume it is for a 401 or 551.  If so there are currently none available on e-bay, A-Z Tractor and the crossover to Stens/Banta 275-970 results in none available.  Hopefully others on this site have better news.
    Share this comment
    Link to comment
    76c12091520h
    Posted
    In stock, along with RJ axle seals if you're still looking.
    Share this comment
    Link to comment
    Thanks for the response Dave!
    Share this comment
    Link to comment
    davidtmercer
    Posted
    Good to know that Brian at K&B has the pulley.  I will remember to include him in my searches for wheel horse parts in the future.
    Share this comment
    Link to comment
    oliver2-44
    Posted (edited)
    The pulley Brian and A-Z sells is a machined steel same size pulley.
    If your wanting period correct the original one was cast steel and had the 1608   number cast in it.
    The inner drive pulley and outer implement pulley are the same.
    So if you have one original pulley, get one of the machined steel ones and put it under the belt guard, and then put the original cast steel one outside the belt guard... and you look oriiginal.
    Edited by oliver2-44
    Share this comment
    Link to comment
