  • Please Read
  • Sign in to follow this
    Center Deck Spindle and Pulley
    Bar Nuthin
    • Closed
    I'm not sure what model/year this deck is, but appears that the center spindle has been replaced with an older double-D. Makes for an interesting cut since it's a tad bit longer that the two outside spindles.
    Looking for the correct spindle and pulley.  Also, I'm not sure it has the correct length blades - so, if anyone can help me identify what deck this is....  no ID plate on the deckIMG_2251.jpg.fb501404399106f7abda49df43d4d498.jpgIMG_2235.jpg.07ea221c712dc7de2a40f707403f772a.jpg
    User Feedback
    peter lena
    Posted
    @ bar nothin  was snoopin  around and found a similar cure for your set up ,
    recently got all 3 spindle for a good price , way to go  , give him a shout pete
    Share this comment
    Link to comment
    Bar Nuthin
    Posted
    @peter lena Great find! I hadn't considered aftermarket parts. I'll do some research.
    Share this comment
    Link to comment
    peter lena
    Posted
    @Bar Nuthin  related PTO MULE DRIVE  pulleys are also a very important part of that , personally repacked mule  drive bearings , easy also go after  pto cone drive , needle bearing (  clean out , regrease , hi temp grease ) LUCAS GREEN CHASSIS ,  outer sealed bearing , NAPA , that entire set up can / should , move easily by hand at pto to deck , down slope , a screaming belt clutch is telling you of bearing related problems , its the functional detailing  / verifying , smooth easy belt drive , that is what you want , pete
    Share this comment
    Link to comment
