Up for sale is my 1995 520H, with just over 700 hours, and a 50" grader blade. NO I will not separate the two. Since I've had the tractor I have changed out all fluids and filters (engine and transmission), greased it up, new LED headlights, new fuse holder, a new battery, and a steering wheel knob. Perhaps the most shocking part of this tractor is the 9-pin connector isn't smoked, all warning lights work, and the harness isn't hacked up! The tractor starts and runs fine but has a drinking problem (very thirsty) and every once in a while I'll need to close the choke a little to calm her down but a new carb is included with this sale. Also included in this sale is a grader/belly blade that has a replaceable cutting edge. This belly blade is originally a 5XI blade but has another mounting bar welded in the frame to allow it to work on the 3/4/5/C series. Now for the bad: the volt gauge sometimes works (it has power so it is the gauge) and the gas gauge sticks which I never cared that much to fix either of them since I just use the machine. All four tires hold air fine but one of the rears is missing a hubcap. $1,000
1
1
