KC9KAS 4,743 #1 Posted November 17, 2017 I am trying to connect a new voltage regulator to a starter generator. I have looked at every thread on Red Square dealing with S/G VR's as well as diagrams on the net. My regulator has 4 terminals. F- Connects to the Field on the S/G G- Connects to the A on the S/G L- Lights or accessories B- Battery On the A terminal of the S/G the "start" wire should be connected either from a heavy duty switch or solenoid. Now comes my dilemma....The G terminal on the VR is also grounded to the VR mounting, thus grounded to the S/G and the frame and finally the negative side of the battery. It appears to me that there will be a "dead short" when activating the "start" mode. Positive to the A post that is also wired to the G on the VR, thus ground. Am I missing something or is my VR not right? The VR says "for positive OR negative ground". I am dealing with negative ground. Share this post Link to post Share on other sites
953 nut 57,754 #2 Posted November 17, 2017 Take a look at this. Share this post Link to post Share on other sites
rmaynard 15,903 #3 Posted November 17, 2017 I'd look in an older Kohler K-series service manual, electrical section. It shows the wiring for a starter generator setup. Share this post Link to post Share on other sites
953 nut 57,754 #4 Posted November 17, 2017 Older Wheel Horse wiring diagram seems to match up with Bob's post from Kohler. Share this post Link to post Share on other sites
ol550 830 #5 Posted November 17, 2017 Does your new regulator have another terminal on the bottom? Possibly the A terminal. Share this post Link to post Share on other sites
KC9KAS 4,743 #6 Posted November 17, 2017 48 minutes ago, 953 nut said: Take a look at this. 48 minutes ago, rmaynard said: I'd look in an older Kohler K-series service manual, electrical section. It shows the wiring for a starter generator setup. 16 minutes ago, ol550 said: Does your new regulator have another terminal on the bottom? Possibly the A terminal. Fellows. I have looked at everyone of these diagrams multiple times. The 4th terminal on the bottom of the VR has a "G" on it and it goes to the "A" post on the S/G....as does the start wire. The issue I see is a circuit from the positive side of the battery through the solenoid to the starter feeding + voltage to the G terminal that is grounded causing a dead short. Share this post Link to post Share on other sites
953 nut 57,754 #7 Posted November 17, 2017 Is the "G" terminal actually grounded or is it just labeled "G"? Share this post Link to post Share on other sites
JPWH 6,250 #8 Posted November 17, 2017 This is the VR on my 854. Share this post Link to post Share on other sites
953 nut 57,754 #9 Posted November 17, 2017 Found this wonderful drawing. The "G" terminal is GENERATOR! 1 1 Share this post Link to post Share on other sites
KC9KAS 4,743 #10 Posted November 17, 2017 7 hours ago, 953 nut said: Is the "G" terminal actually grounded or is it just labeled "G"? It is labeled "G" (for generator), but when I did a continuity test, it was grounded. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,234 #11 Posted November 17, 2017 Most likely a high impedance ground through the windings in the generator. Can you measure real low ohms? It may give you 1 or 2 ohms where a chassis ground will give you 0 ohms. Garry 1 Share this post Link to post Share on other sites
KC9KAS 4,743 #12 Posted November 17, 2017 2 hours ago, gwest_ca said: Most likely a high impedance ground through the windings in the generator. Can you measure real low ohms? It may give you 1 or 2 ohms where a chassis ground will give you 0 ohms. Garry This may be what I am seeing. I did speak with a mechanic at a tractor dealership this morning. I showed him the wiring diagrams and explained what I was talking about. As he looked at the diagram, he said it was a "standard" diagram for s S/G VR setup and it will work if the S/G and VR are all working properly. I do have to polarize the VR before I attempt the start the engine. I know all electrical items work/operate on SMOKE, and if the smoke comes out, they are shot!!! Thanks to all that responded and tried to help me understand what I had and was dealing with! 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,234 #13 Posted November 17, 2017 I recall SOI stating the polarization is not necessary. Once you use the starter the voltage regulator is polarized. Garry 1 2 Share this post Link to post Share on other sites
KC9KAS 4,743 #15 Posted November 17, 2017 @953 nut and @gwest_ca Thank you very much for adding this information! I miss SOI...anyone know what happened to him? 1 Share this post Link to post Share on other sites
Handy Don 13,333 #16 Posted December 11, 2021 On 11/17/2017 at 5:18 AM, KC9KAS said: It is labeled "G" (for generator), but when I did a continuity test, it was grounded. On 11/17/2017 at 5:37 AM, gwest_ca said: Most likely a high impedance ground through the windings in the generator. Can you measure real low ohms? It may give you 1 or 2 ohms where a chassis ground will give you 0 ohms. Garry I agree with Garry here. Also, when checking resistance, always be sure to check both polarities (i.e. take two readings, switching the black and red probes in between--nearly all meters use DC to test ohms!) Share this post Link to post Share on other sites
