JAinVA
Predator engines
pfrederi
Would love to see a couple pics of your mounting!!
Aldon
Ditto
JPWH
I'm also interested.
elcamino/wheelhorse
@JAinVA Well Jim you should have had your wife on the tractor . Your hat says it all . Glad you got the rig to work.
JAinVA
Jim
    Even with my glasses I can't read the hat.Darn good eyes buddy.I have been wrenching some more on this thing trying to beat the rain.I have some more pictures of the install but not the closeups of the mounting
setup yet.I got the hood mounted but what had to be done to the hood is not for the faint of heart.The headlight mount had to be removed as did part of the brace on the flywheel side.What came next will give some you pause but the side of the lower hood had to be bulged out to accommodate the air cleaner.Before any of you go Ethel, look what some idiot did to a perfectly good WH hood the bottom is really rusted badly.
The engine is drilled and tapped to bolt on the pto engagement bits so that is a plus.I will get more pictures if you folks want to see them.
  • Like 5
chex313
So Jim the Headlights need to be removed for the HF 13 HP but from the other threads on the HF 22HP the bigger engine fits with the headlights in? I ask because I spent a lot of time straightening my hood to except new headlight housings and I do not want to have to pull them out...even if it means spending more for the bigger motor.
tom2p
could do something neat - high powered headlamp on one side - and an exhaust outlet on the other side
similar to an old Ford Thunderbolt - but instead of converting inboard headlights to intake one headlight will be converted to exhaust
JAinVA
I can't remember if the the headlight mount needs to be removed or just the headlight.You can get a 13 Horse Predator exhaust stack( the go cart guys love the Preds) on E-bay and mount an aftermarket muffler so the head lights remain.I didn't know this when I did the swap so with a badly rotted hood I just hacked until it covered the engine.I would recoment the remote stack and aftermarket muffler as the stock Pred 13  exhaust is louder
Edited by JAinVA
  • Thanks 1
chex313
Thanks , that sounds good. I'll go look at the engine...I thought it was the intake and airfilter in the front.
Edited by chex313
chex313
Jim, I started on this engine swap this morning...Mounting the spacers under the plate put me way off in height for center of shaft pulley (Clearly its much easier to mount that way tho)
So I lowered the plate and put the spacers under just the motor and that got the height right.
Did you pull the cotter/hair pin on the bottom (Under the Pulley's at raised tab portion of plate) of PTO engagement mechanism to compensate, and that is why you were able to put the spacers under the plate.
If so did that have any effect on the clutch working?
Thanks
Edited by chex313
Cvans
I've been very impressed with my Predator engine so far.
cschannuth
You will love the predator. I have a little story about my brother that he won’t know I’m telling. He bought a minibike for his kids about 15 years ago from a farm store and it had a 212 cc predator on it. And that thing still starts and runs like a top today. The highlight of the story is that as anal as I am about maintaining and maintenance on my stuff, I’m not sure my brother even knows that that engine has oil in it. It’s never been checked or changed and it still is a blast to drive after all these years. I’ve had one in my 606 roller for several years and it is my work horse.
D_Mac
I have been waiting to pick one up for my Lambert project but have yet to been able to get one. They are always sold out. They told me to try again tomorrow. Has anyone tried the 6.5hp one? If so where do you find the pulley to fit the shaft?
JAinVA
chex313,
    Yes I removed the cotter pin and allowed the pto bow to rest at the bottom of the curve on the plate.The pto worked fine.
  • Thanks 1
chex313
2 minutes ago, JAinVA said:
chex313,
Thanks, Yeah that had me stumped for a half hour , trying to figure our how my math could be so far off LOL . :confusion-scratchheadblue:
I like the way you did it better, but I have the motor up on the risers now....
JAinVA
I didn't have any pictures with the engine on a 520 until now. Post us some pictures when get done.
Edited by JAinVA
chex313
Bending the hood the way you did Jim may be the best option...Aftermarket doesn't fit...:scratchead: The hood is about 4 inch's from closing.
Edited by chex313
add comment
SylvanLakeWH
I put one on my WHrat WHrecker... pretty easy fit and starts first pull every time... I had the pulley in the junk... er... parts pile...
chex313
I ordered online , the stores are out of a lot of stuff...Shipping was only $6.99 .
Edited by chex313
JAinVA
chex313,
 worst part of the hood issue is I had to cut the left brace off.I had a hood that was badly rotted at the bottom so I really didn't care.The Predator now is on one of the 520 tractors and the crane boom required a custom hood..
DSCF9104.JPG.2c3353204db0fc4d68d38319ddfcc95b.jpg.b9c5c3e41e652c97d89449fb320ab99f.jpg
Edited by JAinVA
elcamino/wheelhorse
@JAinVA Jim have you had any problems running the PTO on the predator ?
JAinVA
The short answer is no.The Predator has ball bearings supporting the crank just like a Kohler.The Onans have bearings similar to an automotive engines.All the pto  mounting bolts on the Pred are SAE and not metric.If you mount the spacers(1 1/4") under the Onan plate the PTO bow has to be lowered  by removing the hairpin clip and letting the bow rest  as pictured.Putting the spacers under the engine eliminates this issue but then you run into the heads from the engine bolts possibly hitting the frame.
One other thing I know you asked about before is battery charging of the Pred.The one I use keeps up with the winch,no issues.
Edited by JAinVA
  • Thanks 1
D_Mac
Was it shipped to your house or to the store?
12Horse Paladin
THERE IS NO JUNK.
Only nonpretty not-yet-essential-PARTS...
Edited by 12Horse Paladin
  • Similar Content
    • cyrus
      By cyrus
      1996 416-H Wheel Horse Garden Tractor
      Model # 73423
      1355 hours
      Features Electric Clutch Hydrostatic Drive Hydro Lift (mid & rear) Accessories 48" 3 blade mower deck Model #78360 Newer Blades 48" single stage High Chute Snowblower Model #79360 Side Wings for 60" cut sidth Newer Chain and Drum Sprocket 20lb Rear Wheel Horse Wheel Weights Rear Wheel Skid Chains Soft Side Snow Cab Rough but useable. Other info New Battery New Hydro Lift Cyl Hoses New Main Electrical Wire Harness Recent service (Engine Oil, Hydro Oil, Filters, and Chassis lube) Tires are in good shape with no leaks A bit cold blooded, but starts and runs great once warmed up uses no oil.
      located in Zeeland Michigan, purchased new from Westenbrook Mower in late 95. My parents are moving to a townhouse and have no further need for their trusty horse. I have my own, so off to new pastures for this one.
      Pick up only.
      8509515355704655080.mp4
    • t_furl43
      By t_furl43
      A really nice 1995 wheelhorse 416H runs and drives great no leaks only 920 hrs, motor runs strong, starts right up, brand new back tires 23x10.5x12, has slot hitch, comes with 42” RD deck and 42” snowplow, wheel weights and all 4 hubcaps, I’ll also throw in an extra set of tires, will need a seat but that’s it, pickup in millersville pa 17551, price is negotiable, will trade for an Economy Powerking tractor or John Deere 318
    • Bill D
      By Bill D
      I picked up a low hour, (189.6) abandoned 416h yesterday.  Does anyone know what size the o-ring is that seals the carb to the air cleaner?  Mines cracked and I expected it to break in pieces when I remove it there by making it useless for sizing at the hardware store.  Also, the voltage regulator is missing.  Has anyone tried used a regulator from a Kawasaki as a replacement?  I have a couple here and thought about trying them.  Can anyone tell me if this engine has the governor spacer with the tab?  Thanks.
    • Brockport Bill
      By Brockport Bill
      416 Hydro Tractor For Sale - please see photos. Just over 700 hours on meter. Powerful Onan 16 Hp ---  Has Automatic transmission and Hydraulic lift........New filters for tranny, engine, and fuel. New engine and trans oil. 2 new spark plugs. Only a few operating hours on near new Battery. Rear "Ag" Tires plus excellent tread front tires - Rims in excellent condition. Tin looks good. Front and rear lites work. New PTO safety switches. Also available For Sale is 48 inch re-conditioned mower deck for $425 - shell plus lift carriage assembly, all sand blasted clean to remove all rust, then two coats primer and two coats final top coat paint. Mower blades cleaned, sharpened and balanced. Rollers and wheels good condition. Also available For Sale: 48 inch plow unit - complete frame with necessary parts, springs, angle control lever, etc. Plus, like new re-conditoned blade had rust cleaned, then two coats primer and two final top red coats, newly welded reinforced iron bottom plate, plus rust cleaned and re-habbed painted wear edge blade with new carriage bolts @ $290. Also available For Sale: Rear Axle Bracket for plow, tiller, etc set up @ $65: All items cash pick up Hudson River Valley, Poughkeepsie NY area. Please Send private message to contact
    • Rollo416H
      By Rollo416H
      I'm new here, but I have years and miles of dealing with electrical issues with my 1997 416H, engine Onan P216G (I am the only owner) . Problem description: the start circuit turns the starter over fine, but no spark at the plugs or the coil sockets by spark tester.  The ignition trigger tests good by connecting a test light to the coil positive and and the ignition trigger negative lead, plenty of light flash from the test light in unison with the engine turning over. So, I conclude the ignition trigger, replaced 3/18/2021 along with the coil is good.  I have followed the "Demystification" wiring diagram in detail and there is 12V at the coil positive terminal, wiriing is solid (for now), all those damn safety switches, key switch,  and relays work too. I conclude that the coil is bad since the primary side tests 3.1 OHM and the secondary tests infinite OHMS (1. displayed on multimeter).  Two coils (Onan part# 166-0820) have NEW dates of 3/2021 and 8/2021, and yes both have the same test results mentioned. Infinite OHMs to me means the coil windings are broken. The most recent coil came from Onanparts.com and tested as mentioned above when it arrived.  Onanparts won't take anything back!  There are a lot of coils on ebay and various suppliers from China.  Maybe good, maybe bad, who can tell? And most suppliers won't accept returned electrical parts. Please help: What are good test readings for a GOOD coil (primary and secondary). Who do you recommend as a reliable supplier for a new coil?
      Thanks for any help!
      Rollo416H
