12 hp Kohler 1,014 #1 Posted March 24, 2017 I just picked up this wheel horse for $100, I know it doesn't have the original engine, but I'm not sure what model the tractor is. I originally was under the impression that is was an 854 but it doesn't appear to be that.if anyone has an idea of the model I would like to know. 6 Share this post Link to post Share on other sites
littleredrider 409 #2 Posted March 24, 2017 Id say a 502 or 702....but doesn't look like it has the original motor... 2 Share this post Link to post Share on other sites
12 hp Kohler 1,014 #3 Posted March 24, 2017 No it doesn't have the original motor 1 Share this post Link to post Share on other sites
HorseFixer 2,013 #4 Posted March 24, 2017 (edited) Your going to have to be a private detective look underneath and measure the bolt distances Width (side to side) Length (front to rear) where the original engine was bolted down and then do a comparison to see if a Kohler 702 or Techy 502 or 552 was in it. A 502 was pull start and 552 was electric start. That will get you closer to really know. Good Luck! Edited March 24, 2017 by HorseFixer 1 Share this post Link to post Share on other sites
Elkskin's mower junkyard 1,117 #5 Posted March 24, 2017 its more than likely a early 753. look at front axle its not a 62 axle Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,157 #6 Posted March 24, 2017 Looks like a 1963 serial number Garry 1 Share this post Link to post Share on other sites
12 hp Kohler 1,014 #7 Posted March 24, 2017 Ok thanks for the info I will check that stuff out Share this post Link to post Share on other sites
Racinbob 11,378 #8 Posted March 24, 2017 I think Garry nailed it again. It's not a 64 based on the steering wheel and not a 62 based on the front axle. The 854 also had a different dash plate and I think I see a starter switch which wasn't on the 64's. 1 Share this post Link to post Share on other sites
stevasaurus 22,956 #9 Posted March 24, 2017 The 1962s did not have the star wheel for the lift lever...it is a 1963. Now check the bolt holes to see if the Tecky or the Kohler would be original. Share this post Link to post Share on other sites
Elkskin's mower junkyard 1,117 #10 Posted March 24, 2017 37 minutes ago, stevasaurus said: The 1962s did not have the star wheel for the lift lever...it is a 1963. Now check the bolt holes to see if the Tecky or the Kohler would be original. both frames are same tecs used a riser looking at it. it does have a rise but it dont mean anything because someone could of stuck it on. the real way is belt gaurd which is absent Share this post Link to post Share on other sites
12 hp Kohler 1,014 #11 Posted March 24, 2017 Yeah, I'm going to try to pick up a belt hard soon Share this post Link to post Share on other sites
