meadowfield 2,650 #1 Posted January 4, 2015 To follow up my plough conversion, here's the lift assembly needed. Firstly the beefy bar to run from the deck lift arm. Then two bushes for the rocker shaft Then a piece of 18mm bar for the shaft with the ends threaded to retain it. It all fits nicely with the fuel tank in place. And the view from above with the link bar in place. And with the plough fitted. 8 Share this post Link to post Share on other sites
Stigian 1,234 #2 Posted January 11, 2015 Nice work Mark, much stronger than a lift cable.. I'm guessing you can get plenty of down force with that 1 Share this post Link to post Share on other sites
