Operator
Three point mower
Operator
OK guys I have a three point rear mower off my D that I use on my C-195 but I need a new belt on the drive in deck. NLA on the right one, anyone else have to replace theirs? I don't like spending $25.00 on belts that aren't the right length and not being able to return them after getting dirty. I'm up to a B-138 but that is still too short.
Suggestions ?
Randy
pfrederi
What model is your deck? The parts listing for my 5-0900 60" 3 pt mower call for a belt #103236 still availble from Toro for only $130 (or more depending on source).
These decks were made by Woods based on their popular and widely used L59 series ( I have one of those as a belly mount for my Case Tractor.) The spindles bearings and seals are all availible from Woods and Woods part number cross to CR/ Timken etc. for much less $$$.
The belt you need is a Woods 24004 (that is on mine now). After market belts can be had for around $20-30. The descriptions vary bu tehy seem to be about 133-135" one spource says B-132 wquivilent. Are you sure you have your routing correct? There is a fair amount of tension adjustment possible.
Operator
Thanks Paul! I don't know model no. no tag. The routing is very twisted up isn't it? I'll check my sources for those belt numbers , I went to our local parts supplier here.
I tought of drilling a new closer hole on the one idler pulley, or putting a smalleer pulley on take up pulley which I have shortened up all the way.
I'll see what I can come up with, thanks
Randy
pfrederi
Maybe this will help....do you have the manual? I have a lot of the woods equivalent part numbers for spindle bearing seals etc.
  • Similar Content
    • BuffaloD200
      By BuffaloD200
      Finally getting around to working on my ark loader.  The previous owner said he thinks the problem is with the spool valve.
      As I've learned a bit more about hydraulics now, I'd like to get this all sorted out.
      I noticed the power beyond port is connected to the reservoir return.  Is that right?
      Anyone see anything blatantly incorrect?
    • ccs002
      By ccs002
      Looking for a complete hydro pump for a D-160. Tractor is missing everything from the rubber coupler disc back. Also willing to buy a complete tractor for parts, the closer to Harrisonburg VA the better. Thank you.
    • tractorboy79
      By tractorboy79
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
