Lane Ranger 11,069 #1 Posted July 16, 2012 I finally found a very nice Wheel Horse garden tiller implement with the idler pulley Mid-A-Tach, the idler pulley belt guard and belt. I have a rear axle bracket to attach this to one of our tractors -probably a C model with a little more HP than a B-100. The guy I bought it from had it on his C-160 and showed me how well it operated and how easy it was to set up on the tractor. He had the long belt for it that is also in good condition. This thing fit nicely in the trunk of a 2005 Camry with no problem ! 1 Share this post Link to post Share on other sites
Sparky-(Admin) 21,773 #2 Posted July 16, 2012 I dont how much more HP you need than 10? I know we have a couple guys here running tillers with only 8hp. Either way, nice find. Mike............. Share this post Link to post Share on other sites
stevebo-(Moderator) 8,382 #3 Posted July 16, 2012 i run my tiller on my 310 with no problem. Share this post Link to post Share on other sites
Forest Road 594 #4 Posted July 16, 2012 Great find! I've seen them run with a 10hp at 1/2 throttle. Have fun! Share this post Link to post Share on other sites
Lane Ranger 11,069 #5 Posted July 16, 2012 Thanks guys for the info. I am looking forward to using it. Share this post Link to post Share on other sites
kpinnc 13,149 #6 Posted July 16, 2012 Same here- I use mine on my 310-8, and I'd swear I could till pavement with it. 10hp will be plenty! Share this post Link to post Share on other sites
B-100 Dan 7 #7 Posted July 16, 2012 Great find, and with all the pieces too!!! Don't worry about that B-100 having enough power to run it, it has MORE than enough to do the job. I'd love to have one, just have to keep beating the bushes. 1 Share this post Link to post Share on other sites
MalMac 1,332 #8 Posted July 17, 2012 Of all the different tractors I have used to till with I use my 8hp C-81 the most. It tills up just as good as my 520's do. Using a whole lot less gas for the same amount of work being done. Share this post Link to post Share on other sites
can whlvr 993 #9 Posted July 19, 2012 hey lane,i see on the pics that your tiller does not have the spring bar called the lift arm,i looked on parts tree for mine and its part number 104823,no longer avaiable,so if you need the pic for it with a tape measure beside i will do it later this week,very easy to fabricate Share this post Link to post Share on other sites
Lane Ranger 11,069 #10 Posted July 20, 2012 Actually Don it does have the l shaped piece attached to the tiller that the eye bolt and spring lift assist attach to. I just noticed it on there cleaning the thing the other day. The pice I am going to fabricate is the angle iron piece that attaches to the top of the rear attachment hitch that goes on the axles. Apparently, the spring attachs direct to it with a small hole drilled int he angle iron. I am thinking of using my 1976 B-100 as a dedicated tractor for this. Thanks for the tip though, from what I hear the spring assist is helpful to lifting on a non hydro lift tractor! Share this post Link to post Share on other sites
Tankman 3,520 #11 Posted July 20, 2012 Nice find! Good luck with your "BIGGER" garden! :greetings-clappingyellow: Share this post Link to post Share on other sites
bowtiebutler956 650 #12 Posted July 21, 2012 Nice find! Looks to be in great shap! Matt :flags-texas: Share this post Link to post Share on other sites
can whlvr 993 #13 Posted July 22, 2012 ya the spring really helps Share this post Link to post Share on other sites
brandonozz 168 #14 Posted July 25, 2012 I ran my tiller with a C120 and had plenty of power. I use the tiller to work my garden but also to till small food plots. I get a little impatient while tilling the plots (they take a while) and sometimes go a little too fast. I bet a 10 HP will work great. The additional HP doesn't help if you cant get it to the ground and what I have found is when you go too fast in hard ground the belt will slip long before you bog down the engine. Enjoy the "dirt slinging." 1 Share this post Link to post Share on other sites
Davey 0 #15 Posted February 12, 2013 Does any know the length of the belt for c-81 wheelhorse rottotiller Share this post Link to post Share on other sites
Wheel-N-It 2,969 #16 Posted February 17, 2013 I use mine on the 12hp Wheel Horse you see in my Avatar. It works great being powered by a 12hp Kohler. I see no reason why yours will not till just as good being powered by a 10hp Kohler. You are gonna really like how nicely it will break up your garden. Share this post Link to post Share on other sites
brandonozz 168 #17 Posted February 18, 2013 I have a question about the "spring assist" for you guys that have them and possibly have used the tiller without the spring. I don't have one on mine and really dont have any problem lifting the tiller (now the turn plow is a different story) but with the spring do you find that the tiller doesn't till as deep as it would without the spring? I didn't know if any lift may make the tiller ride a little higher when moving forward. I know there are some tillers (like a pull behind craftsman) that actually recommend adding extra weight to the tiller to push it down if needed. Share this post Link to post Share on other sites
rick 238 #18 Posted February 19, 2013 Interesting question- I may sell my Wheel Horse tiller, since it won't till as deeply as my Troy-Bilt Horse tiller. Maybe someone has the answer... Share this post Link to post Share on other sites
Bigwhip 0 #19 Posted May 8, 2014 Do you know by chance what the part number is on the flat guide pulley that attaches to the tiller it's self as mine locked up and I am looking for a new one? Thanks Tom Share this post Link to post Share on other sites
jachady 130 #20 Posted May 8, 2014 I run my tillers with no lift spring. I found that with the spring if the tiller hits harder ground, it won't dig in as much. It also really causes the tiller to bounce when you hit a rock or other hard item. If you can't lift the tiller, then thats another story. However, without yhe spring you may need to gusset your lift arm as it will bend over time causing the thumb release to jam. Sent from my SPH-L720 using Tapatalk Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,187 #21 Posted May 8, 2014 Do you know by chance what the part number is on the flat guide pulley that attaches to the tiller it's self as mine locked up and I am looking for a new one? Thanks Tom Tom, Tell us more like what tractor this is on or a model number on the tiller. Garry Share this post Link to post Share on other sites
AMC RULES 37,144 #22 Posted May 8, 2014 Another really nice score there Lane. Share this post Link to post Share on other sites
Olratlr 25 #23 Posted May 14, 2014 Really good find now enjoy. Share this post Link to post Share on other sites
