JamesBe1
PTO Quick Connect
JamesBe1
I am finally putting together my 50" tiller for my D-180. Thanx to Jeff (Hodge71) for helping me out with welding the last two parts together for me. And thanx to Steve (Prater) for send me a pic of what the tiller drive shaft end should look like.
I have rounded up all the parts, and received all new hardware (well, mostly). The last of the paint is trying, and I a few minor bits on order (spline stub).
I went to check my quick connect on my rear pto, and it is pretty rusted. After a half hour of PB-Blaster and beating on it with a hammer, it finally have it all the way out from it's former stuck all the way in position (towards front of tractor). Also, I can get it to spin in the all the way out position. I have to tap it with a hammer to get it to go back in, but then it is stuck, and have to use a hammer to tap it back out.
Anybody have any tips for freeing up a PTO quick connect that probably hasn't been used ever?
Are they difficult to take apart and clean and repair?
Any help would be appreciated.
Thanx,
James
1maidenfan
Mine had a snap ring on the back side of the collar, I removed that and slide the collar back to remove the ball bearings and cleaned everything really good. When apart I took a small, really small file and cleaned all the internal splines. When cleaning was done I lubed everything really good and kept working it back and forth. Works really good now.
I had a rusted piece of shaft stuck in mine.
Good luck and have fun. :wwp:
post-4490-0-07682400-1338695364_thumb.jp
post-4490-0-92928300-1338695479_thumb.jp
This was stuck in mine.
post-4490-0-23982300-1338695603_thumb.jp
After alot of work and a few :confusion-confused::soapbox::angry-screaming::angry-banghead: she is ready for work.
JamesBe1
Fantastic. Thankyou for the pics. They make all difference in the world. I will be doing that today, and of course I will take lots of pics.
j
JamesBe1
I took some terrible pics, but I figured I would share them to show the progress.
Here is what I am working on:
I found and removed the snap ring on the back side of the collar and pushed the collar back and removed the bearings.
Then I tried to move it forward, and it wouldn't budge. It spun nicely, but wouldn't move forward. I found the snap ring in the front and removed that just to get it out of the way for later.
I finally had to resort to a puller with a socket to match the quick connect. It still wouldn't budge. WTF?
I took the puller off and scratched my head for a while and decided to put it back on and give it an all or nothing effort. I figured that I would just fix anything that happened to break. This time, I got smart and skipped the socket and put the puller in the center of the quick connect.
I started tightening, and shortly, it gave way and started turning easier. Funny thing was, I couldn't see any movement on the collar. Something was moving but not the collar. Turns out that the whole quick connect assembly was pulling off the spline shaft on the end of the PTO rod. Oh well, at least it was progress. I figured that I would just have to replace a roll pin and be good to go. I kept tightening until it came off:
I tried moving the collar forward or back, and it wouldn't move. It spun nicely, but wouldn't' come off. Hmmmm. I took it to the barn and beat on it with a hammer on the anvil. It finally came off. Turns out that there is in inside snap ring in the collar, and when you remove the rear snap ring (from step 1), and move the collar back too far, the internal snap ring gets caught in that groove. Beating it with a hammer is the only way to get it apart (at least for me).
I have everything soaking in degreaser for a few hours before I throw some rust reformer on the parts and reassemble it.
Oh yeah, I checked, and there doesn't appear to have been a roll pin holding the assembly on the spline shaft. It was just pressed on.
JamesBe1
Success!
After I soaked everything in the purple degreaser stuff for a few hours, I cleaned everything with hot soapy water. Thankfully my wife is great about my doing stuff like that in the kitchen sink. She is inured to that by now by my having strange parts all over the house.
Anyhow, I painted everything down with rustoleum rust reformer and let them sit overnight to dry.
This morning, I put everything back together. Problem was, the rust reformer made everything sorta sticky and things did not want to move even with lubrication. I re-read your post and the words 'small file' caught my attention. So, I spent 15 minutes filing all of the surfaces that were sticking together. I put it all back together, and it sorta worked, except it looked like the bearings would fall out at the slightest jar.
I scratched my head for a little while and kicked myself for not taking more pictures before starting, and finally I figured out that I had the slip collar in the wrong direction. I took it all apart and put it back together correctly, and it works perfectly.
Pics are attached:
BTW, thankyou very much for sharing your pics. I would have been dead in the water without them and without your assistance. Next round is on me!
jeremi3210
That rusted peice of shaft that was stuck in your pto looks just like the pump driver for the d backhoe i rebuilt the hydro trans in.
  • Similar Content
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
    • BuffaloD200
      By BuffaloD200
      Hey all, I need to install a drive belt on my 75 D180 for my snowblower.  I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure.  The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell.  Do I have to remove the PTO pulley?  That seems to be a required service item.
      Same question for my 80 D200 as well really.
      Using the recommended 4L490W belt.
      Thanks
    • ihatephones
      By ihatephones
      I got a D-180 for $250, and the governor is messed up, the points won't open or close, and I took it apart and was being stupid and messed some stuff up in there, and now I need a new one.
      Where can I get one that's not on eBay for $200?
      I also forgot to say it was a Kohler K482, and I'll throw some pictures of the tractor in as a treat.
    • Southern_Secret
      By Southern_Secret
      Hello fellow Horse Heads long time no post for me, life gets crazy & a lot of things change sometimes but anyhoo. So back a few years ago when I first got my 1994 314-H I had it at my shop going threw it. One of my customers walk past as im working and said, you know I think Iv got a Wheel Horse & im thinking "no you dont buddy". I give him my # to send pics thinking it was a big waste of time & after getting the pics I realized he did have a Wheel Horse! I hand shake bought it right there, asked him to bring it to my store & he said no problem. Well after almost 2 years it is finally in my orbit. I know very little about it other than his father-inlaw got it new and used it around his house moving snow and stuff. His father inlaw moved down south here when his daughter got married and gave the tractor to my customer because he had a farm & his the inlaw had no use for it anymore. Same with every barn find, "it was running when parked" 8 years ago, said one of the axel seal is leaking. Im happy and hope I can get it back in running order soon cause it is going to be handy around the truck farm!!
      I will post Pics as soon as I reinstate my membership
