JamesBe1
D-Series Headlight Gromets
JamesBe1
So, since I have my tractor in pieces to replace the engine, I figured I would strip and paint a bunch of parts. I took the headlight assembly apart, and was going to strip and repaint it, but the paint wasn't really all that bad. Also the decal and pinstriping were in good condition too. I decided to just mask them off and repaint after a good cleaning.
The headlight bezels were a different story. They had a fair amount of overspray from previous paint jobs. Some of it was blue paint. There was also oxidation of the rubber, but no dry rot at all. After enquiring in one of the threads about restorer/protectant, Andy (wheelhorseman) recommended silicone grease from the hardware store. I didn't have any on hand or feel like buying some, but I had a tube of vacuum grease around. I figured it was close enough.
Here are the shots of before and after I tried removing the overspray with WD-40. That myth is busted as far as I'm concerned. I had to use a sanding pad and dishwashing soap with hot water to get most of it off.
Here are some shots of before and after the vacuum grease treatment. Not too bad, but we'll have to see how it hold up.
Here are some shots of the bezels back in place with the lights installed.
Here is the assembly back on the tractor. I shoulda wiped the dust off of the grill before taking pics. Sorry about that.
So, what do you all think?
KC9KAS
Looks nice and shiney!
Those "D's" just look so massive!
wheeledhorseman
You've done a good job there James and they've come up well.
Easily overlooked and after all, if you ain't makin' dust then you ain't working hard enough!
(At least the grille's on square - I famously photographed my 'D' for the resto thread not realising that I hadn't put the grille back on properly. Doh!
Andy
1maidenfan
Looking good :banana-wrench::handgestures-thumbupleft::happy-smileygiantred::text-bravo::omg::woohoo: :wicked:
312Hydro
Looks great! Those "D"s are sure growing on me!
  • Similar Content
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
    • BuffaloD200
      By BuffaloD200
      Hey all, I need to install a drive belt on my 75 D180 for my snowblower.  I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure.  The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell.  Do I have to remove the PTO pulley?  That seems to be a required service item.
      Same question for my 80 D200 as well really.
      Using the recommended 4L490W belt.
      Thanks
    • ihatephones
      By ihatephones
      I got a D-180 for $250, and the governor is messed up, the points won't open or close, and I took it apart and was being stupid and messed some stuff up in there, and now I need a new one.
      Where can I get one that's not on eBay for $200?
      I also forgot to say it was a Kohler K482, and I'll throw some pictures of the tractor in as a treat.
    • Southern_Secret
      By Southern_Secret
      Hello fellow Horse Heads long time no post for me, life gets crazy & a lot of things change sometimes but anyhoo. So back a few years ago when I first got my 1994 314-H I had it at my shop going threw it. One of my customers walk past as im working and said, you know I think Iv got a Wheel Horse & im thinking "no you dont buddy". I give him my # to send pics thinking it was a big waste of time & after getting the pics I realized he did have a Wheel Horse! I hand shake bought it right there, asked him to bring it to my store & he said no problem. Well after almost 2 years it is finally in my orbit. I know very little about it other than his father-inlaw got it new and used it around his house moving snow and stuff. His father inlaw moved down south here when his daughter got married and gave the tractor to my customer because he had a farm & his the inlaw had no use for it anymore. Same with every barn find, "it was running when parked" 8 years ago, said one of the axel seal is leaking. Im happy and hope I can get it back in running order soon cause it is going to be handy around the truck farm!!
      I will post Pics as soon as I reinstate my membership
