pfrederi 20,866 #1 Posted March 23, 2011 Just spent 90 minutes plowing spring out of driveways (6" of new snow and more coming) But it is time to think spring. I got a moldboard plow last fall and need to mount its clevis hitch on a tractor. Question is which one. I see pictures here of various models plowing but the dirt looks like good dirt i have mostly clay and a whole bunch of rocks. How much HP and 8 speed or hydro??? Share this post Link to post Share on other sites
qd-16 15 #2 Posted March 23, 2011 My 856 with a k-181 has no problems pulling a moldboard plow. getting enough traction seems to be the biggest issue for me. Share this post Link to post Share on other sites
farmer 1,081 #3 Posted March 23, 2011 I would agree with Al, Its not so much about grunt, as grip. So good tyres and weight. Transmission?..depends on how strong your arm is. :thumbs: Share this post Link to post Share on other sites
squonk 47,373 #4 Posted March 24, 2011 In the 60's my dad plowed a fairly large garden with a 604 with the factory "Town & Countries" on the back with no weights and chains and the stock 6 HP Tecky hand grenade supplying the power. :wh: Share this post Link to post Share on other sites
Jim_M 179 #5 Posted March 24, 2011 RJ's are only 4 horsepower and they plow just fine. I prefer a manual transmission over a hydro for plowing, but either one will do the job. Share this post Link to post Share on other sites
VinsRJ 723 #6 Posted March 24, 2011 RJ's are only 4 horsepower and they plow just fine. Even a RJ35 with 3.5hp plows pretty well..... although really slow. :thumbs: Share this post Link to post Share on other sites
mavfreak 11 #7 Posted March 24, 2011 slow is the key, get better traction that way! Share this post Link to post Share on other sites
6wheeler 676 #8 Posted March 24, 2011 I agree as well. Traction is more important than horsepower. You are only pulling either a 8", 10" or12" plow. Of course, more horsepower will make it pull easier but if you spend more time spinning your wheels than pulling, it will seem like you ain't accomplishing anything. I like the 8spd myself, because I can change gears as conditions change. Also, I think an important point. If you go too fast, it is hard to control your tractor. But by the same token, if you go too slow the dirt will not roll over. As you do it more and get to see what the machine is capable of, the better job you can do. If you do get good traction and the plow is working well it can actually lift the front of your tractor through torque. This makes it interesting to steer and stay in the furrow. But, it sure is fun . Share this post Link to post Share on other sites
WHEELMAN 1 #9 Posted March 24, 2011 I plow 4 or 5 gardens every spring with a one bottom plow with my 1276. It has a k301 12 hp. I need to use chains with rear wheel weights and weight on the nose to keep it in the row. 8 or 12 hp means nothing without traction. good luck ! Share this post Link to post Share on other sites
SNYFIX 13 #10 Posted March 24, 2011 It's a trick but alot of how you plow is how the plow is adjusted. Thats what the hand crank (Brinley brand) does for you. To much "down" and the plow digs right in making plowing almost impossible. To much "up" and the plow will just ride along on the top of the ground doing nothing. Properly set the plow and the tractor will work perfect together. Share this post Link to post Share on other sites
squonk 47,373 #11 Posted March 24, 2011 I agree as well. Traction is more important than horsepower. You are only pulling either a 8", 10" or12" plow. Of course, more horsepower will make it pull easier but if you spend more time spinning your wheels than pulling, it will seem like you ain't accomplishing anything. I like the 8spd myself, because I can change gears as conditions change. Also, I think an important point. If you go too fast, it is hard to control your tractor. But by the same token, if you go too slow the dirt will not roll over. As you do it more and get to see what the machine is capable of, the better job you can do. If you do get good traction and the plow is working well it can actually lift the front of your tractor through torque. This makes it interesting to steer and stay in the furrow. But, it sure is fun . My dad used to lean back against the backrest on the 604 and the front wheels would be way in the air. I don't recall how straight the rows ended up being :wh: Share this post Link to post Share on other sites
boatman 3 #12 Posted March 26, 2011 :wh: HI, I plowed garden with c-125 8 speed for years. I added 25lb nose weight and was able to always plow in second high. had 50lb weights on each rear wheel and chains. I was pulling a brinly 10" plow. Used to plow with a hydro but after a couple rounds, oil would be so hot hydraulic would hardly raise plow. I prefer manual tranny for hard pulling :thumbs: Share this post Link to post Share on other sites
d200 0 #13 Posted March 26, 2011 I prefer using hydro for plowing and tilling but I like my manual for pushing snow around. I wish I had a low option for my b tractor. Good luck Share this post Link to post Share on other sites
pfrederi 20,866 #14 Posted March 27, 2011 Thanks for the input . I am going to use a C-81 I got at the show last year. I have some 6.00x12 snow tires, some chains, and 50 lb weights for each side. I will swap out the front wheels for some older narrower ones, some where I have weights for front wheels.. Going to be awhile yet, still have snow on the ground.... Share this post Link to post Share on other sites
Dale 0 #15 Posted March 29, 2011 my C-81 does a great job. I have 105lbs on each wheel, plow setup and traction are more inportant than hp. But I would like to have a hydro so my son could plow without my help lifting at the end of the row. these pics are from last fall Share this post Link to post Share on other sites
