cwilson 0 #1 Posted November 6, 2009 My Commando 800 came with a severely rusted through mower deck attached. The frame that connects the deck to the tractor is rusty but usable. My question is; has anyone successfully attached a scraper blade to this frame, taking the place of the mower deck? I'm cheap and I just need to spread soil to level low spots. No scraping of existing soil or gravel moving. I intend to cut up an old steel tank to make the blade. Share this post Link to post Share on other sites
TJ 183 #2 Posted November 6, 2009 I can't help you, "butt" I bet MACGYVER could. :notworthy: Share this post Link to post Share on other sites
KyBlue 655 #3 Posted November 6, 2009 Here is the factory version.. Thanks duff, I hope its okay I borrowed your photos Share this post Link to post Share on other sites
cwilson 0 #4 Posted November 6, 2009 That's what I have in mind. I guess using the mower frame would mean only a very thin blade would fit. Now to either find one of the factory models or crank up a CAD program and start taking measurements. Share this post Link to post Share on other sites
sorekiwi 761 #5 Posted November 6, 2009 A few mwmbers have built their own blades, and at least one has been documented here: http://www.wheelhorseforum.com/index.php?...der+blade+build http://www.wheelhorseforum.com/index.php?...der+blade+build http://www.wheelhorseforum.com/index.php?...der+blade+build Share this post Link to post Share on other sites
ronscat 2 #6 Posted November 7, 2009 Mine here: Ron Share this post Link to post Share on other sites
cwilson 0 #7 Posted November 7, 2009 That's exactly what I was looking for. Thanks Ronscat. I have a friend cutting up an old water tank as we speak. If the blade proves strong enough I'll make a toolbar for a cultivator.... Share this post Link to post Share on other sites
Duff 206 #8 Posted November 8, 2009 Thanks duff, I hope its okay I borrowed your photos Any time! Honored that you did! Duff :notworthy: Share this post Link to post Share on other sites
Doubletrouble 10 #9 Posted November 8, 2009 Keep us posted on the build. I could use one myself, but then again who couldn't use more WH attachments :notworthy: Share this post Link to post Share on other sites
jla1257 2 #10 Posted November 18, 2009 In need of a grader myself, I found these plans http://www.vintageprojects.com/tractors/grader.pdf on line and am toying with the idea of adapting them to fit my 1257. There is an architectural salvage yard near me where I can get some old, thick pieces of cypress. I am considering cypress because of its natural rot resistance. Or, the other option is to find a section of used 21 Share this post Link to post Share on other sites
rickv1957 72 #11 Posted November 18, 2009 An old roadgrader bolt on cutting edge would make a great start,that is what Ron,s appears to be,Rick Share this post Link to post Share on other sites
cwilson 0 #12 Posted November 18, 2009 I've been looking for a wear plate, but like I said, I'm cheap. I'm at a disadvantage in this area because we have a steel mill that buys from the public and most people take their scrap there. Share this post Link to post Share on other sites
876wheelhorse 46 #13 Posted November 23, 2009 ok are most of these hooking up where the deck hooks up? I think i seen some fabbed up to hook up where the blade would hook up on the rear axle??? I have a plow here to cut up but just need some dimensions on what to do. i think it would be easier to make one that mounts to the rear mount. let me know thinking on building one now Share this post Link to post Share on other sites
ronscat 2 #14 Posted November 24, 2009 Rick, you are exactly right - on Ron's -part of an old road grader cutting blade. It can be rotated with the one bolt (actually 2 bolts) at the top front and back and the several holes in the plate. The blade was free from the County road department. Ron Share this post Link to post Share on other sites
cwilson 0 #15 Posted November 24, 2009 I'm still working on gathering the bits and pieces I need to complete mine. Unfortunately, we have a steel mill here that buys scrap from the public and that means that very few sources for it are available. Once I get the pivot plates and supports for the back of the blade, I'll be posting the build progress.... Share this post Link to post Share on other sites
